14ff ID
Discussion in 'The Garage' started by k20, May 2, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok confusion sets in. I am lookin at disk brake kits for my 14ff. It is out of an 88 suburban and from the yr designation it should not have [ QUOTE ]
    From azkickin "The drum is on the backside of the hub and the studs have to be pressed out to remove drums."
    [/ QUOTE ] However, from another site I have found that the later models (86 on up) the drum should be removeable without pullin the axleshaft and hub but I dont see how it can be done. From teh pic below, do I need the kit for the earlier axle, or the later axle? Thanks guys. [​IMG]
  2. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    That is the standerd drive the stud out variety of 14 ff. /forums/images/graemlins/thumb.gif I just did the swap on mine this weekend.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    You have the early axle. /forums/images/graemlins/waytogo.gif
    When you get the kit installed, it will look similiar to this. /forums/images/graemlins/peace.gif /forums/images/graemlins/waytogo.gif
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    sweet guys, thanks, this axle does have the ribbed center section like the later models, but its the earlier style outters.......odd....o well, the earlier style seems to be cheaper kits.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    o yeh one other thing, did either of you guys use the kits w/ teh ebrake, if so how did the install go, and whose kit did you use? So far I have found 3, Azkickin's, Offroad Unlimited, and TSM mfg. Just curious.
    Also, for those of you using the caddy calipers, does anyone make the arms, springs, etc that will be needed to use the ebrake?
  6. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I did not opt for an e-brake for the time being. Right now, I have an auto tranny....but someday if I go manual I think I will get the e-brake system set up. /forums/images/graemlins/waytogo.gif
    I did not use a kit for my rear dics....I pieced it together. /forums/images/graemlins/waytogo.gif
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I got an auto too, but, i like extra security, least if lose brakes for some reason, i got a prayer.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I haven't seen the pull-off drum on any 14FF until '92 - and even then, only in a heavy 2500 Burb or a 3500 SRW.
    The drums on my '91 were also the conventional "back-mounted" style.
