14FF leaf spring pin/bolt size?
Discussion in 'The Garage' started by dyeager535, Nov 4, 2005.
  1. dyeager535
    26,976
    My dad just gave me a call and said that one of his rear leaf springs broke the centering pin/bolt that holds the leaves together.
    He's a LONG ways away from a Napa or anything large like that, so finding the right piece is going to be tough to impossible at this point. Hardware store is going to be his only option.
    I see mention that the hole in the spring perch is apparently 9/16", but in searching the board here, I can't quite figure out what diameter the bolt/pin itself is. I'm going to call him back and see why he doesn't just pull the remainder out, but in the meantime, somebody here has gotta know!
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    For the rear spring packs, you need a 3/8-16 x 3" long hex socket cap screw, washer, and ny-lock nut. The head of the cap screw is the same dia. as the head of the spring pin.
    Buy zinc plated grade 8, put it in, and don't look back. :waytogo:
  3. dyeager535
    26,976
    Thanks!
    Hopefully there is a place in town that has those in stock. I know I've seen them around here, but a smaller place may not. Crossing my fingers. :)
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    or just grind the head of a grade 8 bolt round.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Those are about the only thing I buy at 4WP. $2.50 a pair.
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Dorman makes some that I always use. They're 3/8". They're a couple bucks apiece for 6.5" long ones and under a buck each for 3.5".
    The 6.5" ones make good gas tank strap threaded rod.
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    That'd be Socket Head Cap Screw...:smile1:
    Rene
  8. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    yep...thats what i have on my zero rate in the rear...and in the front i just used a 3/8" grade 8 bolt, 3.5" long because of the zero rate...used a poor mans lathe to grind the head smooth...drill and angle grinder. Worked like a charm and ill do that from now on.
