14FF lengths
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Emmettology 101, Apr 19, 2001.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have heard that there are two different Dually axle lengths. One is about the same size as a stock Blazer axle and one is shorter. How much shorter is the short one compared to the normal K5 size one?
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I dont know about shorter but on a dually p/u is is alot wider than a stock axle. My 14 on my dump truck the outside duals are no wider than the cab of the truck. I'll measure it tonight unless someone beats me to a measurement. 74" for some reason rings a bell for a backing plate distance...but I might just be making that up.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    10-4, Thanks
  4. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    Does it matter if you put a dually 14 on a k5, i was under the impression that you couldnt put those on, just the single 14s.
    Not all Rednecks drive ugly trucks---umm, nevermind <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I think the difference is not 2 different dually axle widths, but rather the difference between "dually" and "dual wheel chassis cab". The dually trucks have a normal bed with the “flares” to cover the outer wheel. These trucks have a wider axle than “normal” trucks. The chassis cab trucks have a narrower rear axle so the outer tire is not sticking out.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You can put pretty much anything anywhere with enough motivation and money. However, if you are talking about "bolt in" you are right. At a minimum, all 1 ton axles will require relocating the spring perches. And dually axles will require shortening to keep stock track widths.
    Bad Dog
  7. Cavalry
    Oct 1, 2000
    978
    OK I dont know where I pulled that outher measurement from but backing plate to backing plate is only about 45" The inside duals almost touch the spring packs. HTH
    Luke
    84 K5 [​IMG]
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am actuallt checking into it for a friend that wants a shorter one for a Je*p.... Yuk!
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Thats what I thought...... And what I told him the other day. Now I am just trying to find measurements....
    Thanks.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    10-4.. Thanks!!!!!!!!!
