14FF no oil?
Discussion in 'The Garage' started by MNorby, Feb 3, 2003.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Blew up my 14FF this weekend out playing. Put a nice hole and dent into the cover and something spit out. I drove it about 6 mile salready back to town with no oil (like 5 mpg with the front helping pull too) My shop is 5 more miles out of town. Do you suppose it is gonna hurt anything (bearing, etc) driving it slow for that distance? It is welded per the article on this site about wleding the valleys but I think I am gonna weld it solid or put a detroit in it now but gotta get to my shop to tear it apart. Anone got a spare 14FF cover???? /forums/images/graemlins/tongue.gif Thanks.
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I believe it would hurt it.
    Could you just put some oil in it and use some JB Weld the quick setup stuff to patch the hole?
    Eric
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Gears will get ruined within minutes of driving without gear oil to lube them and keep them cool, doesn't matter how slow you go there is still going to be metal to metal contact which builds heat in a hurry.
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Clean the cover,Patch hole with duct tape,add lube,tape should hold to shop.I'd pull cover to be sure no stray parts loose to get in gears and put tape on both sides. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  5. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    it will hurt it.
    by the way , i found out the hard way of course that
    i peice of aluminum foil with some jb weld will work
    patching a hole in the diff cover and get you all the way home and even farther without leaking. /forums/images/graemlins/grin.gif
