14ff out of dually, Will it work?
Discussion in 'The Garage' started by Danny Joe, Sep 27, 2005.
  1. Danny Joe
    Danny Joe 1/2 ton status
    Feb 10, 2005
    134
    Blythe,California
    I know this might sound dumb to some of you but the only reason I am asking is because I don't know. Okay so here it is. Will a 14FF out of late 70's dually work on my 77 K-5. Info sure wouls help. Thanks, Danny Joe. :doah:
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    You're gonna have to move the spring perches and shock mounts but otherwise yes. IIRC a dually axle will make your front and rear equal widths WMS to WMS instead of the usual 3" narrower in the rear.
  3. Danny Joe
    Feb 10, 2005
    134
    Blythe,California
    Thanks for the reply, it helped.
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    all the brake parts are diffrent to the dully. so if you get a disk kit for std axle it wont work. do some searching on 14ff axles and see the big diffrences. but yes it can fit yours .
  5. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    No
    Measure the wms to wms, and make sure it is a 14 bolt...
    A dually 14 bolt is significantly NARROWER because it would be out of a cab and chassis truck. The outer dual (with all the wheel's offset) is in the same place as a standard wheel on a srw 14 bolt...
    A dually Dana 70 is the wider one.
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Ooops, 70's came in the duallies back then didn't they? Sorry about that, totally disregarded the year.
  7. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    This would require some serious thought: If it is indeed a 14FF, I don't think you will be able to move the spring perches outward the 1/2" required for a K5 without going disc brakes. I have had to bleed the rear brakes on a 14FF dually, and it is a bitch to get on the bleeder screw(tight fit next to the spring pack). While discs on a dually rear are feasable, it is quite a bit more expensive. Measure, measure , and measure again just to be sure.
    Jimbo
  8. Danny Joe
    Feb 10, 2005
    134
    Blythe,California
    I want to thank everybody for the replys. Answered alot of my questions. Thanks, again.
  9. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    A dually 14bff will work if you change the drw hubs to srw then you have a srw axle.
    The only draw back is that there are no bolt on disk brake kits for srw this way. you have to weld the disk brake brackets to the tube as the flange is too far back.
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'd like to see somebody try and move the spring perches out 1" per side on a C&C axle to make it fit the K5 spring spacing. :rolleyes:
    (Okay.... you could do it if you put on discs or did something else with the brakes ;) )
