14ff question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigmack, Jan 10, 2002.
  1. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Does a 14ff out of a 3/4 ton truck have the correct spring perch spacing so that it will bolt directly into a 1/2 ton truck ? If not is the 3/4 the same as a 1 ton ? Any info would be appreciated.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    3/4 ton is a direct bolt in with the possible exception of the E-brake cables, depending on which setup you get. Minor fab will swap the 1/2 ton cables over from what I hear. 1 ton has narrower spring perches that must be moved to mount under a 1/2 or 3/4 ton.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    yep, I swapped in a 14FF from a 75 into my 1/2 ton '86. just E-brake cables had to be changed
    '86 GMC shortbox 3/4 ton
    <a target="_blank" href=http://www.picturetrail.com/mnorby>www.picturetrail.com/mnorby</a>
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  5. bigmack
    Jan 3, 2002
    478
    Tennessee
    Great, that answers my question.
    Thanks for the info.
