14FF QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87BrnRsd, Aug 22, 2003.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I will be swapping a 14ff out of a 1 ton into my 87 K5 in the next couple of months. I know that the spring perches need to be relocated 1 inch out, but am unsure of the shock mounts. Where do you move the shock mounts in relation to where they are on the 1 ton 14ff, and where they need to be to fit my K5? Thanks. /forums/images/graemlins/thumb.gif
    -Harrison
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> THe shock mounts on each side of the axle need to be swapped to the opposite sides of the tube, for some reason they are backwards in the 1 ton. At least that's the way they were on the 87 1 ton 14b that I put in my 78. On mine the passenger side goes forward and the driver's side goes back, the 87 14b was opposite.</font>
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    You'll also need to get a conversion Ujoint where your driveshaft bolts to your pinion yoke. 1310/1350 joint. Your e-brake might not match up either so you'll have to fab up something to work.
  4. 87BrnRsd
    Apr 21, 2003
    2,457
    Im going to be running an echobit flip in the rear, so I bought a lengthened rear shaft with the 1350 series yolk already on it so I dont need the conversion joint. As far as the e-brake, what is on it that doesnt match up? I have heard that it might not match up, but why wouldnt it, and why is it that it MIGHT NOT match up? Thanks for all the help yall. /forums/images/graemlins/thumb.gif
    -Harrison
  5. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    What year is the 14FF out of? Inorder for the E-brake to work it needs to be out of an 84 or newer I beleive. Your e-brake set up is like mine. You have one short(drivers side) and one long(passenger) coming off the axle. On the older axles the cables were the same legnth.
    I have had my 14 bolt in my K5 for about 6 months now and I hate no having the e-brake. The biggest thing you have to pay attention to is that the rear brakes will not automatically adjust as the pads start wearing. You will have to get under neither it adjust the star so the rear brakes will keep pulling their fair share.
    Hope that all made sense.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Close. '83 and up are the years. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  7. Muley
    Sep 26, 2002
    364
    Eagle Mountain, UT
    R U sure?
    I can not remember how many times I have reference the LMC catalog for the trucks and K5's and I am 99.9% sure it states 84.
    Not that LMC is a 100% accurate reference manual, but I have found that it give you something to visualize with.
  8. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    I took the backing plates off of a 84 1 ton chevy van with a S/F 14 bolt, and it bolted right up to my 1 ton F/F 14 bolt. worked perfect.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    R U sure?
    Funny you should ask. Who's word are you gonna believe when you are reading flase info from a catalog and from someone who has 18 years of experience from studying the GM line of trucks. /forums/images/graemlins/blush.gif /forums/images/graemlins/thinking.gif
    Now to do a friendly wager with your: what have you got to lose in a bet with me? $5? $10? $50? Hell, make it $1 million dollars! Go to your nearest GM dealer and look up that info. Just be prepared to pay me the $1M. /forums/images/graemlins/wink.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  10. Muley
    Sep 26, 2002
    364
    Eagle Mountain, UT
    LOL, If I would have had your resume, then I would not have doubted you. That is good to know. Gives me one more year to look for.
