14ff ratio?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazerboy72, Jun 21, 2002.
  1. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    What is the most common gear ratio in 14ff it is in a 1976 truck if that helps anything <font color="blue"> </font color>
  2. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    All the ones I've seen have been 4.10's. Both my '75's have 4.10's They're both K20's also. Hope that helped.
    Dan
  3. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    The ratio is stamped on the ring gear....all you have to do is pull the cover and write down all the numbers you see and post them here.....
    Then you will KNOW for sure what the ratio is!
    BTW -&gt; I currently have two 14BFF's one has 4.10, and the other has 3.73
    Military axles (CUCV) most commonly have 4.56s, I think.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    the most common ratio i have seen is 4.10.ive checked out 2 or 3 at the junk yard and all three had this ratio.i also had a friend with 14 bolt and 4.10.
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i've also noticed that (2wd)trucks with the I-6 292 engine and sm465 tranny came with 4.56s. not certain if all but the ones that i've found do have the 4.56s
    also 2 out of 3 K20 disels that i've run across came with 3.73s.
    ARQ.
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i got 4.10's out of a 78 3/4 ton
    NITRO
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i found 4.10 locking in a 76 454 auto 3/4 ton even though stamping on axle tube said 3.73 - it was incorrect/false stamping, also i once had had a stamping code that said 4.10 on an '85 9.5" and I opened it up and it was actually 3.42....
