14ff ring gear diff numbers.. what ratio?
Discussion in 'The Garage' started by 78Suburban, Jul 28, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Ok, I pulled my 14ff cover, it all looks good in there. open carrier :D
    3 GM 3992484 11 41 2 78
    that's on the ring gear. What ratio is it? My guess from the driveshaft turning trick was 3.73. Was I right?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    3992484 = part number
    11 41 = gear ratio. 11 pinion teeth and 41 ring teeth. 41/11=3.73
    2 78 = date code
  3. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    3.73 is your ratio. see the 11 and 41? divide 41 by 11.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    the tire turning driveshaft counting trick DOES work :thinking:.. I was just glad it wasn't a gov bomb!! My lazy butt just not pulled the cover.
  5. divorced
    Jul 20, 2004
    5,115
    Ya, the turn-the-tire method does work well. I usually turn the tire 20 times while someone counts the driveshaft revs. It's real accurate this way.
