14FF Spanner Socket
Discussion in 'The Garage' started by kennyw, Jul 16, 2006.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Anyone know a source for the 14 bolt wheel bearing retainer nut spanner socket? I haven't really been able to find anything in a quick search this morning.
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    my d60 wrench works on mine....Got it at napa if I remember correct.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Depending on the year of the 14ff it is the same as a D60. I bought mine at work from our car quest store. Try Napa also.
  4. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    i had to modify a socket to fit i had. it was square teeth and the nut was round teeth. took file to edges and bam worked great.
  5. kennyw
    Jun 9, 2002
    13,224
    94
    Thats good info... took my hubs off yesterday and started a disc brake swap and my girlfriends dad asked me if I wanted him to make me a tool for the retaining nuts. So we made up a really nice one on his CNC mill. We made the nubs round to fit the nut perfectly so they won't be prone to slipping like cheap flat ones on my D44/10 bolt socket I got at the parts store. Was after dark when we got it done but I ran out and tested it anyway and it looks like its gonna work great.
    But woke up curious this morning if anyone even made them though.
    Now I need to look up the bearing torque specs too though and run into town for some axleshaft gaskets...
  6. sweetk30
    Nov 1, 2004
    25,552
    547
    50 ft lbs with hub moving . and black rtv sealent.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Don't leave it at 50lbs. or you'll be buying a new hub and possibly axle when the bearing seizes up on you.
  8. sweetk30
    Nov 1, 2004
    25,552
    547
    never had a problem yet and i fix them all the time. that spec has been gotten from lots of shop books and gm book. but most of the time you need to back it off just a bit to line up the keyway.
    also went and checked this also. same specs.http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
  9. kennyw
    Jun 9, 2002
    13,224
    94
    50 ft-lb was the spec I found too...
    here is my Spanner Socket :D
  10. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    4X4high is correct. In the torque table it does say torque to 50 T LBS, However there are notations the have to be read as well. The factory 1978 GM manual, my haynes, and chilton all have a "**" notation that states Back-off nut and retighten to 35 FT. Lbs. then, back-off nut 1/4 turn.
    If left at 50 you will prematurely wear the bearings out. Not to mention overheat the hell out of the hub and spindle.
    Nice socket by the way:waytogo:
