14ff spindle nuts/lockwashers
Discussion in 'The Garage' started by k20, Jan 15, 2007.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Does anyone know where to get the spindle nuts & the lockwashers for a 14ff?
    Buddy of mine has the older style 14ff w/ 2 spindle nuts & a lockwasher and his lockwashers are badly deformed, anyone know where to get new one?
    Or can he convert to the newer style w/ 1 nut, woodruff key, and snapring. Does anyone have the part numbers for that?
    I searched today and only came up with one thread and it said they got a spindle nut service kit, no part numbers, and the thread was a couple years old. Anyone know where to get these?
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh, I would say junkyard too, but the yards around here are slim on 14bolts, is there any negative to using that style locknut?
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    Dorman Part Number for just the spindle washer: (bend tab style) 6180491 $4-5 depending on location
    i think you can get the whole side: thrust washer, 2 nuts and spindle washer for like $25ish
    From the D60 Bible:[FONT=Arial, Helvetica, sans-serif]
    For one complete front axle you need four 33732(lock-nut), two 33733 (lock washer), two 33734 (flat washer). These are Dana patr numbers. All 8 pieces for about $22.00
    [/FONT](same parts are used for 14b)[FONT=Arial, Helvetica, sans-serif]
    [/FONT]
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I should be going back to the junkyard in a few days. They had plenty of 14bff equipped vehicles there. I could snag you a few lockrings if you like...
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh if you can grab a couple that would rock, otherwise thanks for the links guys, can make it work if dont find a 14ff in a junkyard.
  7. sweetk30
    Nov 1, 2004
    25,547
    542
    some like to run dana 60 nuts in the rear so 1 trail fix socket is needed. speeds up the repair as you only need to carry one socket.
  8. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Rockauto list
    DORMAN Part # 618049
    9/16" Thickness 1/16 Keyway Tab L x W 7/64" x 5/32"}
    Front - Lockwasher
    Floating Rear Axle - Lockwasher
    **Sold in packs of 2; Price reflects cost of each individual item, not the pack**http://www.rockauto.com/catalog/getimage.php?imageurl=http%3A//www.dormanproducts.com/images/items/hwrap1/5005310-3.jpg
    $2.11
    DORMAN Part # 618048
    Floating Rear Axle - Thrust Washer
    Front - Thrust
    **Sold in packs of 2; Price reflects cost of each individual item, not the pack**http://www.rockauto.com/catalog/getimage.php?imageurl=http%3A//www.dormanproducts.com/images/items/hwrap1/5005310-2.jpg
    $1.45
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is what I do:D
    Ira
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    We get them from the dealer IIRC, both GM and Ford.
