14ff spring pads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Feb 11, 2002.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    i need to move the perches on the 14bff, my drive angles are horrible. Anyone know where i can purchase some new ones? Also, is it easier to grind them off and torch them?
  2. blazing86
    Dec 24, 2000
    290
  3. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    FWIW, I tried to buy some a couple of years ago without success. Just use box tubing and make your own.
    David
  4. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I ground mine off, but it was a pain. I am going to try a torch next time.
    Steve Frisbee built a set of spring perches for me that I am happy with.
    DJ
    78 K5
  5. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    Can you reuse the perches if your careful when taking them off. I use 2 six degree shims stacked together making for a ridiculous contraption. (12 degrees!) When I get my 14bff I will be doing the same thing as you.
