14FF spring perches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Mar 22, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Are the spring perches on the 3/4 ton 14 bolt sit higher than the ones on the 10 bolt? The reason why I ask this, is because I'm hopefully going to be installing a 14 bolt into my Blazer pretty quick and I was going to put an add-a-leaf to level it out. Is it possible the 14 bolt will level it out a little bit?
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The perches aren higher but the tubes are thicker which will have the same effect. When I lifted my truck, the tallest rear spring I could get was 2" so I also got a 2" block. When I swapped in the 14 bolt, I put in a 1" block and it sits level now. </font color=blue>
