14ff vent tube size????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surpip, Oct 5, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    when i got my axels they diddent have vent tubes, i was able to put a 3/8 NPT barb in the 60 but the 14ff hole was alot larger... anyone have any idea what size it is?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3/8 NPT? Are you sure? That's pretty big! Holy fill hole size batman!
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    not that big but ya im almost positive thats what i used id have to check the tap to make shure
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You realize that a 3/8" NPT plug is over 1/2" in diameter right?
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    nope your way off i just looked the tap, you use a 5-16th drill to drill the hole
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Actually, Tim is right. Pipe thread sizes are way bigger than the number marked would imply, 3/8 pipe thread is indeed bigger than half of an inch. Double check the tap, since the tap required a 5/16 drill bit I'd say it's closer to 1/8 pipe thread.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I *think* 3/8" NPT is 5/8-18 tapered thread.
  8. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I just bought this fitting from the dealer and it measures 7/16" on the fitting that presses into the housing.
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    cool thanks funky cold
    well tim might be right but i read the tap i used it said 3/8-16 right on it so i dont know what to tell ya
  10. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3/8-16 amd 3/8 NPT are two totally different things. A 3/8-16 tap is NOT tapered thread. 3/8 NPT is a tapered thread that you could thread a 3/8" inside diameter pipe into. Thus why it's 5/8" or so in diameter.
    You don't know what to tell me cause you didn't have a pipe thread tap in your hand. /forums/images/graemlins/waytogo.gif
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the tap said exacally 3/8-16 NPT so if thats not NPT i dont know what it is i would take a picture but the writing is a little worn down and it wouldent show up in a picture. also the 3/8 npt barb fitting that i asked for at napa went right in so eaither way it worked and now i got to do the same thing to the 14ff but bigger
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    update***** i was way wrong!! between Tim and the Old- school guys over at Boeing I got schooled. i used a 3/8-16 NC tap on the 60. The hole size on the 14ff is 7/16th but there is no tap in NC for that hole size But they do make a NF tap for that size hole so ill se if i can find a fitting in that size
