14FF W/TSM Caddy Calipers - Ebrake cable @#@#
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcamacho, Jul 13, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    The previous owner sliced the lead and intermediate cables and clamped them. The clamps keep popping off.
    I'm replacing the front cable with one from a yard. While out there I found a slick set up on the fullsize trucks with 14FF's where the central cable adjuster then went to an intermediate cable to the frame rail in front of each side of the axle. From there, a frame bracket attached to a short cable to the drum.
    Q: What the heck are you guys using on similar setup that works. Yeah, forget the pinion brake -I'm still running a 208.
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I used the factory e-brake cables from my '90, I had one of the cables lengthened a little, and fabbed some brackets to use with the TSM kit.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks for the pics. Do you have a photo of where the cables join the center cable at the adjuster? My cables are so bad, I can't tell what the setup looked like originally.
  4. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I did the AZ-Kickin' brackets and the TSM caddy calipers. My lever is on the bottom though. Did you mount them upside down in order to accomodate those brackets and is it a PITA to bleed them?
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I mounted them upside down to keep the ebrake lever above the axle. It is a pia to bleed them. I take the caliper off the bracket, turn the caliper upside right, and put the caliper back on the rotor(not using the brackets) to keep the piston in the correct position. Then bleed them like you normally would.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Here's the thumbnail pic I think you wanted. Just click on it to enlarge.
  7. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks!
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks!
    /forums/images/graemlins/waytogo.gif
  9. rcamacho
    Jul 1, 2004
    1,324
    WA
    Turns out Benix makes replacement cables. I bought a new front cable (from ebrake to rear junction). It looks like there (may) be enough adjustment to take up the slack. Else I'll have to get ahold of someone with a professional swadging tool. /forums/images/graemlins/screwy.gif
  10. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Anybody else have any pics of how they did their Caddy caliper e-brake? I've been playing around with several designs trying to keep the lever on the bottom with the bleeder up but no matter how I look at it, it's a PITA.
