14FF wanted
Discussion in 'Parts & Trucks Wanted' started by beater_k20, Jul 11, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    looking for a 14FF to put under the rear of my '92. i'd prefer something older (70s-80s) that will work with the Sky Mfg disc brackets i already have. 4.10s and an open carrier would be awesome too. anybody semi-local (150 mi +/-) got one they're looking to part with? spring spacing doesnt matter, as i'll be cutting the perches off anyways.
  2. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    only 2 kits for brakes. pop off newer and press on old style. i have seen lots of 88-up style with old style. and if you run 87-down the ubolts will be close to the backing plates. i used a van width and it worked much better and was press on drums so a std kit would work for disks.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    that would work too. the spring spacing is right on the back of the van? how do i tell a pop off drum from a pressed drum?
  4. sweetk30
    Nov 1, 2004
    25,544
    539
    spacing is not same from van to 88-ups. and if tire is off you will see drum on frt of hub for pop off or on back side of hub for press on style. myvan axle was 94 with press on.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have an empty 14bff with a massive rear cover if you can bring me a Dana70 Dually axle! :D
    You can pick this 8lug front stuff also!
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    had a couple of them, couldnt give them away, so we scrapped them. :(
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Am i right in that you could get then new axle to bolt in, and swap hubs to the old stuff and still use your brackets?
  8. sweetk30
    Nov 1, 2004
    25,544
    539
    if you mean switch from pop off to press on. then no is the answer. thay changed the spindle specs and such. that is why there is kits for both styles. i tryed this and it didnt work. shane74 and i made the first kit and i tested it . he sells them in the vendor section in his home page. for the pop off style.
  9. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Good to know.
  10. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    I have one with 3.73s open, not sure on the year but 70 or 80s is probalby about right!
    I'm in Terre Haute IN, $150.
