14ff...what all do i need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NITRO, Jun 25, 2002.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    Im gettin 3/4ton axles, th 350,np203 all for $150 from a fellow ck5er today and was wondering what all i will need hardware wise to do this? will the u-bolts from the 12 bolt stock axle work? thanx for n e help or pointers. BTW, its on a '79 Blazer
    NITRO
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    You'll need u-bolts for a 14ff and the plates, a combination u-joint (someone will have the part number on here). Do you have 8 lug wheels?
    some people say you have to do something to the ebrake, but I didn't /forums/images/icons/confused.gif
    Did you check the gear ratio?
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The Napa part # for the hybred u-joint is 447. You will need new u-bolts, new u-bolt plates, 8 lug wheels. As far as the 350/203, it depends on what trans/t-case you had before. You could need new driveshafts, linkages, shifters, crossmembers, ect.
  4. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    i j ust got the axles. i got a 14ff and dana 44. they are 4.10. i dont have wheels yet. y cant i just use the u-bolts from the stock 12 bolt? o, will the calipers off of my 10 bolt work on the 44? and will the 44 just bolt right in? thanx for all the help
    NITRO
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I believe you can use the 10-bolt calipers on the D44. Should be a bolt-in. You have to get new u-bolts and plates because the axle tubes on the 12-bolt and 14BFF are different sizes.
  6. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    cool, now, what should the #'s b on the ring gear for it to b 3.73? im tryin to sell my old axles to my neighbor but dont know the ratio? thanx
    NITRO
  7. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    To find ratio divide the number of teeth on the ring gear by the number on the pinion. Some ring gears have it stamped on.
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    The part # for the newer style with the inner c-clips is 447. The part # for the older style with the outer snap rings is 348. Just did the swap myself this weekend. 3/4 ton 14b FF from a '77, and I needed part #348. $27.
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Also, the numbers for 3.73's are 41 & 11. /forums/images/icons/grin.gif
