14FF what shocks
Discussion in 'The Garage' started by Dogman12, Apr 30, 2007.
  1. Dogman12
    Dogman12 1/2 ton status
    Nov 12, 2006
    111
    Easthamptom Ma. 01027
    I just finished my 14ff swap and my shocks are maxed out, i have a 4 inch lift and no name or number shocks, are you guys running a rear shock for a six inch lift? Not sure if these shocks were even for a four inch. Any how if anyone would post up what they are running with this setup it would be great.
    Jesse
  2. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    i'm running BDS shocks. not sure how long or w/e but will try and get some pics up. maybe some with a tape up against it.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Did your 14FF come out of a 2wd truck? If so, the brackets are further down than a 4wd.
    Depending on your fab skills, I'd cut the brackets off and shorten them to weld back to the tubes in a position that they are above the bottom line of the tubes. This way nothing can get caught and drag on the shocks. Doing so should give you about 3" back into the shocks.
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    rs 9000's, i think they are 10 or 12" i forget which...
