14FF with Toms axles....how does this work?
Discussion in 'The Garage' started by 88jimmy4x4, Dec 28, 2003.
  1. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I saw this on ebay and was wondering how this works. Its a 10.5 full floater with 6 lug aftermarket axles that dont have a outer hub on them. May sound stupid but how does this work?
    Ebay Link
  2. I was looking at that same axle just today and wondered the same thing. Looks kinda shifty to me.
    Mat
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well I'm not entirely sure on why someone would do it... But it's not too hard... Cut the spindles off the end of the tube and machine a bearing surface inside the tube. Press in a race and theres your wheel bearing. Then just make some kind of retention system for the axle, such as a crosspin drilled through the carrier and shafts. But why?
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    is it made into a simi floater?
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Did you notice the dif cover? I've never seen one out on the market like that one. Its the one that is a bearing-supporting type, like a girdle, made by companies like T/A Performance. Just never knew they (or anyone) made one for the 14FF yet. /forums/images/graemlins/thinking.gif
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I was thinking the same thing. /forums/images/graemlins/thinking.gif That axle is obviously no longer full floating. I would bet that it uses a bearing retainer similiar to a 9" Ford since there appears to be no way to access any C-clips. /forums/images/graemlins/thinking.gif
  8. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Well it is and it isnt. The axles arent held in by c-clips.
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    alright I see how it works /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    But the weight of the vehicle will be supported by the axleshafts, so yes, it's a semi floating axle. Plenty of semi floating axles do not use C clips, the ford 9" being the most common as mentioned above.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Whats that piece between the carrier and ring gear? Some type of spacer instead of changing to a slow case, or thick gear?
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That is the other half of the carrier.
  13. Grim-Reaper
    7,385
    Atlanta
    The axle shaft suports the weight...it's a semi floater. It's set up just like a stock ford 9 inch. It's a crappy axle for a 4x4. When side loaded they bust the bearing races and cut the wheel seals out.
    Good for drag racing though. Bullet proof R&P and fairly light weight for the rest of it.
  14. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    This will make you laugh /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/smirk.gif
    >What was the reserve on this axle?
    > the reserve was 1688.88. If intrested let me know . Thank you for your inquiry
  15. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
