14sf 6 lug w/discs
Discussion in 'Suspension | Axle' started by neverendingproject, Mar 27, 2007.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Sold
    Specs:
    3.73 ratio
    Gov-lock- works perfect
    4340 6 lug shafts
    disc brakes
    homemade rear cover
    new outer bearings and seals
    9/16 studs
    Needs brakes, soft lines and brake "tee" fitting.
    Things to know: This axle is a bolt in for 1/2-3/4 ton blazers, pickups and suburbans, but some modifications will be needed to get brakes to work. The metal piece on the outer brake pad that sticks out perpedicular to face of the rotor will need to be cut off. I cant remember, but I dont think any caliper modifcations are necessary. I thought I completely welded the inside of the cover but it leaks a little from somewhere. Other than the above things, its ready to drop in. Soft lines I used were off a 79 chevette, and calipers were of course eldorado ones, but front calipers will work, you just wont have an e-brake.
    Im Asking 250 local pick up
    Edit: If you want, I will include 9/16 studs for the front hubs, you just have to drill them out. I can also throw in McGard wheel locks and lugs nuts if you want.
  2. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Help me out here as I'm not well versed in custom built rearends yet.
    Is the cover welded onto the differential housing? Or, is it just welded together and then bolted on. I can't tell from the pic. Also, what kind of condition are the gears in? Please excuse my ignorance and thanks for the info.
    Kurtis
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    The cover is welded together then bolted on. Its made of 10 guage steel I think, I cant remember now. I wouldnt have used the axle if the gears werent in good condition. Also, people tell you that gov-locks are crap, but everyone on here says that doesnt apply to anything but the 10 bolt, and its always worked when I needed it.
  4. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    I didn't think it would make any since to weld it on, but you never know. I'll research it a little and let you know if it's something that might work for me.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    If you have any questions, let me know.
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
  7. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    sure, $250 shipped to MA:D
  8. MisterK5
    MisterK5 Registered Member
    Apr 8, 2007
    23
    Under my K5
    PM'd You.
  9. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    wanna trade for a d60ff rear out of a currently running and driving 68 1ton? or my 10b posi rear? just an idea really...
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    That would be a negative. About the only things I would be willing to trade with is a 14ff locker and 10bolt carrier that is some sort of aftermarket locker or limited slip, and a winch.
  11. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    my current 10b has an auburn limited slip and 456 in it. pretty sweet dude. you also get an extra for parts!!! i also got a driveshaft and the homemade style shackle flip stuff.
  12. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Send me some pics and we'll talk.
  13. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    This really is a cherry axle, I've busted my knuckles on it a couple times. The disc set up is worth the price alone.
  14. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Just send it to MA, i`ll take it off your hands....:D
