14sf and 14ff
Discussion in 'The Garage' started by cochino12, Oct 19, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    Ok sf = semi float
    and
    ff= full float? is that right? Can someone explain what that means. Thanks
    yes I did search but I cant find $h*t using the search funcion here.
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    SF is like your 10 and 12 bolts. C clips in the center. If you break an axle shaft then they will "walk out" or the tire would fall over. With a FF your axle shafts bolt to the outer hub letting you roll on even with a broken axle shaft. FF has a larger shaft diameter also I think, larger ring gears 10.5" compared to SF 9.5". I think all of this is correct but I could be wrong also.
  3. mrk5
    Apr 20, 2004
    12,334
    1,043
    Northern Colorado
    To expand a little on the previous post:
    In a Semi-Floating axle the axle shafts subjected to the weight of the vehicle and the torque from the motor.
    Where as in a Full-Floater the axle shafts are only subjected to torque from the motor.
    If this helps, any front axle is a Full-Floater.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    SF, There is 1 bearing on the out side of the axle, all the weights on the axleshaft. On a full floater theres an inner and outer bearing on the out side of the axle, like in a front axle.
