14SF axle tube"flange pattern"?
Discussion in 'The Garage' started by dyeager535, Feb 26, 2004.
  1. dyeager535
    14SF axle tube\"flange pattern\"?
    Anyone happen to know, or can find out, if say an '88 14SF and a 2000 14SF share the same pattern that the brake backing plate/disk bracket bolts to, and if there is a known difference between that pattern for disk or drum brake setups?
    I know the later 8.5" pattern changed in that time frame (bolt spacing was increased slightly, axle flange was rotated about 45*) so a disk brake swap from a 2000 8.5" to 1986 8.5" isn't a bolt and go affair, but if you can buy a 1988 6 lug 14SF, and the disk brakes off of an 8 lug 2000 14SF, and bolt them on, it could simplify a great disk swap.
    (at least for me, who won't ever need a 14FF, but wants disks, my 6 lug wheels, and wants something better than the 8.5", cheap /forums/images/graemlins/smile.gif )
