14SF u-bolt nut size?
Discussion in 'The Garage' started by dyeager535, Feb 24, 2005.
  1. dyeager535
    26,980
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I used the U-bolts and plates from a 14bff on my 14bsf. But I still dont know what size or if they are metric.:grin:
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Pretty sure the SF has 3.375" tubes like the FF does. I just opened up my 1/2 ton spring plate holes a little and made them work...
    Rene
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Should be 15/16". Threads should be 5/8 NF, whatever pitch that is (11 tpi is coarse, I'd imagine 18 tpi is fine, but I can't remember).
  5. dyeager535
    26,980
    Yep, same size tubes, should have used search, but I was in a hurry.
    My measurements didn't come out to exactly what everyone elses did, but the calipers I am using aren't quite big enough to make me feel I'm getting a real accurate measurement, and I believe you guys anyways.
    What are you doing measuring in inches anyways? Aren't you supposed to be using centimetres to cheque things like this? :p:
    Appreciate all the help. 10 bolt u-bolt nuts are 15/16", so unless they changed to metric for some reason later on, 10 bolt, 14SF and FF should all be 15/16" to remove.
    1/2 ton spring width is 2.5" give or take a tiny bit, just in case someone runs across this post at a later date and can use that info.
