15"8lug wheels on 14SF?
Discussion in 'The Garage' started by originalspanksta, Jul 22, 2005.
  1. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    basically , can it be done?
    I have a 14sf from an 88c30 and im wondering if the 15" wheels will clear the drum. Wheels are 8 lug 15x10 steelies with 4.25 bs.
  2. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    im running 15's on my 14b sf with no clearance issues at all, i went down to 15" when I went to 35's.
    Mike
  3. originalspanksta
    Jan 31, 2005
    147
    Philadelphia
    is your 14sf 6 or 8 lug? Im afraid that may make a difference, as mine is 8lug.
  4. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    15's will work, do on mine anyway
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have 15s on mine and clear no problem.
  6. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    will 15's work on a 14 bolt ff. ( think that's whats on my suburban) the brake drums are giant.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, 15's will fit on a 14FF with drum brakes without issues.
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    that is awsome!! all this time I was considering 16.5 wheels, that gives me so much more options... :thinking: :burb: :woot:
  9. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    it is the D60 that causes the problems with 15" rims, you have to shave the calipers to fit the rim with out hitting, that is what I am dealing with right now...to grind or not to grind that is the question.
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    15's fit the Full Floating 14 bolt no problem at all. The Semi floating 14 may need some light grinding depending on the drums. My buddy originally swapped an SF 14 under his Blazer, the fins on the drum needed to be ground down a little to get the rims to seat properly.
    Rene
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    K20 is ff, correct? it has the hubs that stick out with the circle of bolts on them.
  12. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Not all k20's are full floating, if it has hubs then yes, it is full floating.
  13. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    awsome, it has hubs
