15" Aluminum wheel on 14BF/F: wheel spacer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, Apr 4, 2001.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    15\" Aluminum wheel on 14BF/F: wheel spacer?
    Couldn't find a direct answer to this exact question, maybe because there isn't one, but anyway, here goes:
    If I have a 14B FF "filled and drilled" to 6 lug, will a 15x10 Aluminum 6-lug wheel fit over that big drum? I am considering wheel spacers anyway, so would a 1" or 1.5" spacer on each side move the wheels out far enough to clear? These lug studs would be thicker than stock ones, BTW. I am really considering doing this, but it is hard to determine for sure whether or not it would work by measurments alone.
    <font color=green>Stupid tourist at Mammoth Cave, Kentucky: "How many miles of unexplored passages are there?"</font color=green>
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Re: 15" Aluminum wheel on 14BF/F: wheel spacer?
    As far as rear goes I am not sure if they will clear. Steel wheels will clear the drum but I think it is close. The big problem is the front 8 lug rears. They will not clear an aluminum wheel.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: 15\" Aluminum wheel on 14BF/F: wheel spacer?
    I believe on the 14FF, the outside of the hub also has to be turned to fit the center hole on the 6lug wheel.
    But I have heard that with the right back spacing a 15" wheel will fit on a 14FF with no mods..
    <font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>[​IMG]
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I recently bought a set of 15x10 8-lug steel wheels with 4.25" backspacing. There's not much room left between the rim and the drum, about 1/4" or so, but even with the same backspacing I would think the aluminums would still fit as I wouldn't think they would be that much thicker. Also, if you got something along the lines of 3.5" backspacing (which seems pretty common on 6-lug wheels) it should give you more room.
    However, the biggest problem (as Emmetology already mentioned) is trying to work around the large center hub of the 14 FF. There's just not enough room for the 6 on 5.5" bolt pattern without somehow modifying the hub. There's another post talking about this exact subject right now.
    I'm not sure exactly what a "front 8-lug rears" is as mentioned in the other post (sorry, couldn't resist), but you obviously wouldn't have to worry about clearance on the front because of staying with the 6-lug pattern.
