15" Eatons/Wheel Vintiques on 8-bolt Dana44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LittlePig, Apr 12, 2001.
  1. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    I looked through the back posts, because I remember a thread about 15" wheels on 1-ton axles, but I didn't find anything. I plan to put an 8-bolt axle up front on my future rig, but in order to get what I want, I need to run 15" front wheels. I remember reading that steel 15s might fit on the 8-bolt though the clearence would be tight for those big calipers. Since Eaton/Wheel Vintiques sell 15" 8-bolt rims, I kinda have to assume they will fit, but real-life experience would be most appreciated. So far, this is the only hurdle I have encountered in planning my buildup.
    Email: xiaozhu@my-deja.com
    ICQ: 84108805
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: 15\" Eatons/Wheel Vintiques on 8-bolt Dana44
    <font color=blue>They'll fit but you have to grind the calipers. They're not huge, they're the same thing as 1/2 ton calipers. They fit over the rear drums fine though</font color=blue>
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I'm running 15x10, 8 lug Eaton wheels with 3" backspacing. I had to grind the calipers and backing plates to fit. I had to grind even more when I got a spare 15" wheel from Summit with a 4 1/4" backspacing. Pics are on the Midwest Spring K5 posts. thebigdaddyof2, todd
  4. LittlePig
    Aug 9, 2000
    299
    East Texas
    I was afraid of something like that. How much did you have to grind off the caliper? I am concerned with compromising the structure of the caliper.
    ICQ: 84108805
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You only have to grind a little. I ground mine and theres still plenty of material left on them so I dont think strength was comprimised.</font color=blue>
  6. clintsk5
    clintsk5 1/2 ton status
    Mar 2, 2000
    288
    Kingman, Az.
    Have the same set-up...just a littlle grinding...try to fit them..little more grinding till you get it...really not much!!..HINT!!!!!........Have a least on wheel with no tire on it when you do this...(makes lifting it on the truck to make sure it does'nt rub)...it's a lot easier!!!!!
