15 inch wheels on 14b FF?
Discussion in 'The Garage' started by SICNICK, Apr 1, 2006.
  1. SICNICK
    SICNICK Registered Member
    Jan 13, 2006
    59
    Fort Collins, CO
    I am plannin on swappin to a 14b FF soon, obviously ill need 8 lugs, but if I disc brake convert the rear can I run 15 inch wheels? tires for 15's are so much cheaper and easier to find! [​IMG] Thanks!
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    depends on the conversion you do. most are based on 3/4 ton stuff, minor caliper grinding would be needed, depending on backspacing. So yes, with little to no work.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    my 15"s with 4 inch backspace work without grinding. i used DIY4x's kit.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Honestly, this topic is kinda' like kicking a dead horse it's been discussed so much.........
    Anyway, a disc conversion on a rear 14FF typically requires very little or no caliper grinding because the calipers and rotors are spaced further inward from the wheel than a front application.
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    [dead horse]
    15's fit over the largest 14 bolt FF drums as well as over rear disc's...it's pretty rare to need to do any grinding on rear calipers...
    The front end is where all the clearance problems are.
    [/dead horse]
    Rene
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
