15 inch wheels on 3/4 ton running gear
Discussion in 'The Garage' started by WantedaDodge, Jan 17, 2007.
  1. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    So, I have a dana 44 and a 14 bolt under my blazer, I'm wondering what is necessary to run a 15 inch wheel.
  2. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    I wuz wondering the same thing, I have lots of nice 15" tires. A friend of mine said that he's seen 8 bolt 15" wheels... You?
  3. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    I know it's doable. I just don't need a 10 or 8 ply tire on my blazer. The most load it's gonna see is a couple dirtbikes or a couple snow mobiles. i'd like to be able to take advantage of the squishiness and cheaper/more availability of 15s.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  5. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    What about with a 3/4 ton 10B would you still need to grind?
  6. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    Minimal grinding only, mostly on the caliper bracket, not the caliper itself
    you can get 8lug 15" wheels from Summit for like $35ish each
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Is it April 1st already????
    This exact topic has been disccussed about 85 billion times.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Yeh just do some grinding its no big deal, the rear fits just fine.
  9. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    Sorry, I tried the search feature and really couldn't come up with anything, didn't see anything in the tech section so I figured I would ask.
    No, My next question is, if I swap to rear disk brakes, am I going to have fitting issues(the rear disk swap from the tech section using late '70s caddy calipers)
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The amount of grinding will depend on the backspacing of the wheel you are using.
    My rims are 4.25" BS so I had to grind a fair amount. I have disks on the rear and I had to lightly grind the casting flash off of one of my new calipers. I used regular 73-79 K20 calipers.:D
    Here is a pic of the finished grinding.:doah: :D
  11. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    There are at least 2 tech articles that address this.
    For a Dana 60 but same basic thing, and talks about 3/4 axles also.
    http://www.coloradok5.com/d60calipergrind.shtml
    Talks about switching to 8-lugs on a D44 or 10-bolt and discusses caliper grinding.
    http://www.coloradok5.com/8lugconversion.shtml
    About 5.4 seconds of searching found this 4 page thread discussing the exact same thing:
    http://coloradok5.com/forums/showthread.php?t=191768&highlight=caliper+grinding
    Or this 3 page post:
    http://coloradok5.com/forums/showthread.php?t=184406&highlight=caliper+grinding
    Or this post:
    http://coloradok5.com/forums/showthread.php?t=184836&highlight=caliper+grinding
    Sorry for the rant, but I'm going to puke if I see somebody ask this question again.
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Here is my 15" wheels on 1 tons:D.
    No pics of the grinding I did but it was a lot on the front. For the rear I just put them on no mods at all. I have the 13"X3.5" drums on the rear and 4.25" backspacing on 15X8 steel wheels from summit.
    Ira
