15 inch wheels
Discussion in '1992-Present Chevy & GMC models' started by dorucol, Nov 7, 2004.
  1. dorucol
    dorucol Registered Member
    Jan 12, 2004
    16
    Will 15 inch wheels work on a 94 k5?
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    There is no such thing as a 94 K5. Do you mean a 94 K1500 Blazer? If so, I do not think that 15" wheels will clear the front brakes. Also, the backspace on 15" wheels is usually less then the 16" on the K1500, possibly causing premature wheel bearing failure. Otherwise, you can't hurt anything.
  3. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    i got 15in steel rims on my 93 k1500 truck, they are stock 80s style rims and before that i had 15in alcoa look alikes on it, and my brother has a 94 gmc k1500 and he had 15in alcoa look alikes on his too.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i have bolted 15 x 8 ralleys on my 91 K1500, and yes they did seem to fit, however i didnt drive it for any distance with them on, so i dont know if there were any clearance issues.
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    They should fit fine, I see many Z71's with 15x10 Alcoa look-a-likes and 35's runnin' around.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    had a couple friends run 15s on IFS rigs, one had no issue, the other had to grind a very slight amount of material.
  7. andrew.wilson
    andrew.wilson Registered Member
    Jan 19, 2005
    35
    Wyoming
    I don't have any problems on my 97 k1500
