15" rim on 3/4 dana44?
Discussion in 'The Garage' started by muddawg, Feb 17, 2005.
  1. muddawg
    muddawg Registered Member
    Oct 24, 2004
    39
    Susanville, CA.
    Will a 15x12 wheel fit on a 3/4 ton 44 and a 14bolt rear with a rear disc conversion?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Rear definitely, front, depends on the backspacing. 2.75 and less and you won't have to grind the calipers, 3" and more and you'll have to grind the calipers for the rims to fit over.
  3. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    Is there a major amount of grinding? Will this weaken the caliper any?
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It's just a dusting on the caliper itself. The majority of the grinding will be on the leading and trailing edge of the backing plate (either side of the caliper)
    No big deal, tons of guys here run ground calipers on D44's, 10 bolts and D60's.
    Rene
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Not sure if all users can access it or not, but I wrote a tech article on this, and I just updated the pics the other day:D
    It's in the tech articles forum:D
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    In addition to Brian's tech article, here is a pic of the grinding I had to do to fit 15 X10 wheels with 4.25" backspacing.
    Like Rene said, the backing plate (in addition to the caliper) will need to be modified a bit by grinding, hamering or both. I chose to do more hammering to the backing plate for clearance rather than grinding. I just had to grind the opening for the caliper after hammering.
    As far as the rear is concerned, I had to lightly grind only one of the rear calipers on my disked 14BFF. The castings from Autozone varied just enough that I had to knock off the casting flash.
    :waytogo:
