15" rims and 3/4 ton axles?
Discussion in 'The Garage' started by AJMBLAZER, May 25, 2002.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    15\" rims and 3/4 ton axles?
    I know this has been asked to death, but for some dumb reason I never paid attention. I'm talking 8 lug D44 or 10 bolt front axle, and 14FF rear axle.
    What do you have to do to make 15" rims fit over 3/4 ton axles?
    I know they don't clear the D60's of 1 tons, but how about the 8 lug D44's and 10 bolts?
    Are there any normal backspacings (I'm not to hot about 1" of backspacing) that will clear the front and rear brakes?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 15\" rims and 3/4 ton axles?
    Do a search. /forums/images/icons/wink.gif
    I'm sure some people get tired of repeating the answer to this all the time, so do a search and save the time. /forums/images/icons/wink.gif
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Calipers need grinding. More than you think but not enough to effect the strength of the caliper. I run 15's on my 8 lug D44 and they have 3.5" of backspace.
    Rene
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Use 3.75-4.125" backspace. Bolt them on the rear, grind until they fit the front. Thats all there is to it.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    <a target="_blank" href=http://www.members.cox.net/russhuffman/grinding/calipers.html>This</a> is for a D60, but the 3/4 ton stuff is not that much different. You won't have as much to grind, and the brackets are quite a bit different, but this should give you an idea...
  6. Joe T
    Joe T Registered Member
    Apr 28, 2002
    23
    El Cajon Calif.
    When I had my D60 (rear) built, I welded new axle tube flanges on that would accept my stock backing plates. Had the axles made with the 6 bolt pattern, with bigger studs put in
    http://community.webshots.com/user/trihouse
  7. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I called a rim dealer and asked that same question, and they said it would work. They dont make 8-lug 15" rims for nothing.
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The application that 15" 8-lug rims are made for are for old drum brake 3/4-ton trucks. I have even seen a set of 15" 8-lug ALUMINUM wheels. Most wheel places will just tell you it won't work.
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If you have a Les Schab tire store near you, you can get the 15x10 8 lug white spokes for $27. Ugly as [censored]....But 8 lugs and cheap.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I got about the same thing from Discount Tire.
