15" rims and ford dana 60 brakes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Dec 29, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    15\" rims and ford dana 60 brakes?
    Do 8 lug 15" rims fit on ford brakes on a dana 60 with minor grinding, like the Gms or no? I have heard Fords have better front brakes because they are 2 piston.
    Dan /forums/images/graemlins/burb.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Re: 15\" rims and ford dana 60 brakes?
    bump, I am curious too, I know Dan (Krazie87K5) had the Furd Dual Piston calipers...maybe he can inform us on any clearance issues...
    Chris
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    the outer dia has to be under 14-1/2'inch to fit an alum rim so that would be 7-1/4" from center, I want to here this out too....
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    im curious as well. and not to hijack a post or anything but do the ford calipers fit on GM backing plates?
    Grant
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">The ford dual piston calipers dont have enough material to grind to fit 15s. Me and a local tried and we saw that it wouldnt work so he got 16s and they fit
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    I'm putting a set of ford calipers on my rear 14FF axle with e-brakes on them. I have 15"inch 6-lug rims going on over them, I turned the rotors down and made a set of brackets to keep the caliper inside the rim...
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    dude, you need to bring your machine shop down to my house.... that way i can make some cool gizmos as well.
    Grant
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Maybe that's the ultimate way to make an 8 lug 10 bolt or D44 front that will fit 15s....turn down the rotor and use 1/2 ton backing plates.
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You'd have to use 1/2 ton calipers too, since the D60 calipers come real close to the part of the hub that the studs come out of. If you use the smaller calipers then you lose one of the big benefits of the 1 ton axles. </font color>
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You need to search over on PBB.
    From what I remember reading there were a few years where the dual piston calipers would fit but they are really hard to find.
    No they will not work on chevy knuckles.
