15" rims on 14bff and D44
Discussion in 'The Garage' started by az ranger, Sep 27, 2004.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    15\" rims on 14bff and D44
    are there any clearance issues or other problems with running 15's on these axles. I have heard that 15's wont fit over the calipers on D60's w/o grinding, is this also the case on D44
    thanks
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: 15\" rims on 14bff and D44
    My 76 K5 can from the factory with a D44 and 15" rims.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Do a search.
  4. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    i have a 10 bolt with d44 outers(knuckles out) with 8 lugs and i had to grind the calipers and the backing plates. /forums/images/graemlins/grind.gif
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes, you need to grind the calipers to get them to fit over the brakes. The amount of grinding will depend on the amount of back spaceing. If more you have the more grinding. Also though the less back spacing you have the harder it is on your ball joints so it is a toss up of what to do. I run more BS (4.125") and my ball joints seem to last a decent amount longer then the guys who run less (2-2.5")
    They will clear a 14bff no problems.
    Make sure when you grind the calipers that more then 1 wheel will clear the grinding. All rims are a little different and if you need to rotate your tires or mount up your spare that rim may not fit. I learned that the hard way.
    Harley
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    If you go disks in the rear you may have to grind very little, I just had to knock off the "lips" on my caddy calipers /forums/images/graemlins/thumb.gif
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i think grinding the calipers is a very bad idea, and if you do it like the write up says, arent you supposed to blend the ridge so as to not cause a stress riser? I leared a little about metal working in HS but i could be wrong /forums/images/graemlins/dunno.gif
  8. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    I didn't have any problems on my d44, 14b was fine until i did a rear disk conversion, when i had to grind a very minimal amount off, which i could of avoided if i'd been more careful in my measurements place the brakes (made the brackets at home).
