15" rims on a 14bff & d60?
Discussion in 'The Garage' started by PsychoticDeadGuy, Aug 13, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    well, is this possible? my rear 14bff has the 2 1/2 inch brake shoes out of a C30. i dont have the d60 yet but i was wondering if i would be able to put 15" rims on these axles? with what backspacing if it is possible?
  2. jrpeebles
    jrpeebles Registered Member
    Jan 19, 2005
    40
    North Hollywood Ca.
    Yes, it is possible. I run 15" rims with 3" of backspacing. The D60 calipers will require some grinding to clear the rims. The rear should not be a problem.
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    any body else run 15" rims on their 1 tons? i need to know if it is possible. tires cost less with smaller rims. i was either going to run 17s or 15s but i really want the 15". so far i have heard that 15" with 3" of backspacing works...what else?
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yes just liek the above guy said, you will have to grind the calipers on the D60 but on the 14bff they will fit fine.
    Please search next time this has been covered 2132464654616316 times :D
  5. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I have either 2.25 or 2.5" back space on mine with no problems
  7. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, now i need to find some rims. i need 15x10 on 8-6.5...i cant seem to find any that have 4" of backspacing or less. where are they?
  8. sams78chevy
    sams78chevy Registered Member
    Apr 24, 2005
    65
    oregon
    I run 15 inch rims on my 8lug 44, and I had to grind the calipers and brackets and get 3/4inch wheel spacers so they dont rub.
    78chevy 6inch w/shackle flip, 350ci, 650cfm carb, headers 38.5inch ground hawgs
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You won't find them listed on any sites, you have to go to a tire/rim store and make the sales person look thru their books to order them for you.
  11. jrpeebles
    Jan 19, 2005
    40
    North Hollywood Ca.
    Bart truck rims.I think Summit sells them.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    jrpeebles, you need to activate your PM account so you can accept messages. I tried to send you one as I had a question for you.
    My question was: are you Tony's son or what? :confused:
  13. jrpeebles
    Jan 19, 2005
    40
    North Hollywood Ca.
    No, who's Tony?
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Tony goes by TONYP and his last name is Peebles. He's one of the premier machinists on this site. Just saw your name and wondered. :doah:
