15" rims on a d60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bablazer73, Jan 9, 2001.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    15\" rims on a d60?
    is anybody running 15" tires on a d60 front axel? how did you make them fit? I would love to stay with 15" but don't think they will clear when I install a d60.
    your right. I don't understand the jeep thing!
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Re: 15\" rims on a d60?
    I run 15x10 American Racing white spokes and 15x10 Tech mods on my front Dana 60. The wheels are standard backspacing. Stock up on grinder wheels. After making a pass with the grinder, I like to spray a very light coat of paint on the caliper, then test fit the rim again to see where it hits. It is much easier to use a rim w/ out the tire mounted.
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    How much do you think you ground off Pete?
    Thanks.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I had to "clearance" my 3/4 ton front in the same way.I called national tire today. they said the same thing as long as I am using a single piston caliper. what year front axel do you have? single piston calipers?
  5. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Henry & Joe
    See Stephen Watson's reply under same topic on the Off Road Design forum on this board. More or less clears it up!
    Brian
    89KBlazer
  6. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Just guessing, maybe 1/4".
    It was a lot more than on a 3/4 ton. The axle is an '80 and has single piston calipers.
    Pete
  7. Brian 89KBlazer
    779
    Ontario, Canada
    Pete
    What is the backspacing on your wheels?? I just got an email from 4Wheel Parts while I was reading your reply and they have the 15 x 10 Chrome Rock Crawler rims available in the 8 lug pattern with either a 3" or 2.5" backspacing!! He said that grinding to clear the Dana 60 caliper would be minimal!!
    Best part is they only cost $59.95 per wheel.
    I think I just found my new wheels!!![​IMG][​IMG]
    Brian
    89KBlazer
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I don't remember off hand, will have to check when I get home. I know they are more than 3". I prefer to run standard offset rims as they are much easier on ball joints/king pins and steer easier as well. If you want cheap, I bought my white spoke American Racings at Discount Tire for $36 each about 4 years ago.
    Pete
