15'' rims on a dana 60 front end?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 500HP1TON57, Apr 15, 2001.
  1. 500HP1TON57
    500HP1TON57 Registered Member
    Mar 16, 2001
    12
    SEBASTOPOL CA....60 MILES NORTH OF S.F.
    15\'\' rims on a dana 60 front end?
    ok fellas me and bigerik just bet a dollar....he says you can grind the calipers on a dana 60 to fit inside 15x10 rims and I say no way ..as I had to do extensive grinding on a dana 44 just to squeeze them on..... so we leave it up to the vast pool of knowledge available to us through this web site.....what say the bretheren?
    1957 CHEVY STEPSIDE, 1 TON ,TILT FRONT END,ITS BIG AND ITS MEAN AND IT RIPS UP THE GROUND, ITS POLISHED AND PAINTED AND THE TALLEST AROUND<P ID="edit"><FONT SIZE=-1>Edited by 500HP1TON57 on 04/15/01 11:28 AM (server time).</FONT></P>
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Re: 15\'\' rims on a dana 60 front end?
    I have not done it personally but have heard of MANY people doing it on this site. So I would have to say that it can be done. I'll look for the posts. One recently said you have to go with the right offset. From what I have heard I would have to side with bigerik on this one.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    There have been many recent posts about this. Several members of the board are running 15" steel wheels on a D60 front with ground calipers. How much grinding varies based on the wheel and offset but it can be done...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Do a search in the Offroad Design forum. You will find lots of info on it there.
    BIGJ
  5. 500HP1TON57
    Mar 16, 2001
    12
    WOULD LIKE TO HEAR FROM ANY BODY WHO KNOWS FORSURE
  6. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    So then the conclusion was that it is possible to run 15" rims on a dana 60????? Correct?? I will be trying this shortly but would hate to waste the money on the rims. Thanks Guys
    BlazerBoy
    http://generalblueballs.coloradok5.com
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Pay up that doller because it can be done. Best to use a 3in backspace on the wheels. Get the grinder out.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes it does work....
    There are many, many people on the Pirate board and here that are running 15's on a D60. You have to use around a 3" backsapcing and do grinding on the calipers....
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  9. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Can"t speak for 15x10 steel wheels but if there 15x10 aloy then I would say no. I have a D60 with 16x10 Weld forged and 4" back spaceing and I had to grind about 1/16 to 1/8 off to clear the adhecieve weights.
    MAC
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A guy in our club is running 15x10 steel rims with 4.25" backspacing on a front Dodge Dana 60. He had to do a good amount of grinding but he has had no problems with it, though I don't know for sure if the Dodge brake components are a big as the GM version......anybody know?
  11. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    So did I win a dollar?
    <A target="_blank" HREF=http://www.bigerik.coloradoK5.com>http://www.bigerik.coloradoK5.com</A>
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'll bet a dollar you did! [​IMG]
    Bad Dog
  13. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Yeah you can do it. I am running 15x10 steelies with 3 3/4" (I think) backspacing. Lots of grinding (almost scary how much) and they work great.
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
