15" rims with 8 lug rotors???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Obsession, Nov 27, 2001.
  1. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    15\" rims with 8 lug rotors???
    How much of the caliper has to be ground off to allow rim clearance for a 15" rim when using 3/4 ton 8 lug rotors ??? is this really possible???
    thanks
    Ken
    <a target="_blank" href=http://www.blazinobsession.com/>http://www.blazinobsession.com/</a>
  2. Big_Ugly_Diesel
    Big_Ugly_Diesel Registered Member
    May 7, 2001
    60
    Fort Worth, Texas
    Re: 15\" rims with 8 lug rotors???
    It is possible and I did it on my Blazer when I put in a 3/4 ton Dana 44 front. It seems like you grind a lot but most of it is casting slop on top of the caliper. It worked out great when I did it.
  3. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Depends on your rims backspacing.
    On mine i had to grind to the center of the hole on the top of the caliper about a 1/8th to 1/4 inch.
    It'll take a couple of hours to do it, so be patient and if you have a rim that fits with the same backspacing, but without a tire , it'll make it alot easier to check the clerance.
    my .02
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
