15" wheels on a 14 bolt ff
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by codyoffroad, Oct 23, 2002.
  1. codyoffroad
    codyoffroad Registered Member
    Aug 14, 2002
    6
    Montana
    15\" wheels on a 14 bolt ff
    I was woundering if 15 inch wheels would fit on a 14 bolt ff? if so how much back spacing? would they stick ot yery far? /forums/images/graemlins/k5.gif
  2. DeafyHTowner
    DeafyHTowner Registered Member
    Oct 22, 2002
    10
    Houston, Texas
    Re: 15\" wheels on a 14 bolt ff
    sorry to interrupt...i'm a newbie here /forums/images/graemlins/smirk.gif anyways, what is "ff"?? 14 bolts, does it mean that it's really strong or normal?? trying to learn stuff here /forums/images/graemlins/grin.gif
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    check out the technical section on the home page.it has an article on what you are asking.
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    it means "full floater" /forums/images/graemlins/grin.gif
  5. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    yes they will fit. I had 15x10 chrome spokes on my 71 with a 14 FF, they were standard backspacing. THe front is another story though. especially if you are running a Dana 60 as I am... now i regret grinding my calipers as i run 16's at present time but Live and learn I spose.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Mine fit with 4" of backspacing.
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    ...To expand on Bob's answer....Full Floater means that the axle has two sets of bearings to support the axle shaft.
    The main benefit is that the weight of the truck is supported by the bearings and not the axleshaft. On semi-floater axles (10-Bolt, 12-Bolt, and 14SF) the axle shaft not only provides turning forces to the wheel but also has to hold the weight of the vehicle.
    The MAIN reason that you'll want a FF axle is if you ever break an axleshaft.....on a semi-float design the wheel falls out of the axletube, and leaves you stranded. On a FF design, you can still get home. And getting HOME is the name of the game!!! /forums/images/graemlins/thumb.gif
    ps. A 14 bolt SF axle with a rear disc brake conversion would also get you home, but that's a topic for another time. /forums/images/graemlins/cool.gif
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i have 15x8's on mine..cant remember the exact back spacing right now but i think it is right around 2 1/2 to 2 1/4..but my tires stick out about 2inches on each side...not too bad...but last time the chp pulled me over he gave me a hard time.....kinda bs if ya ask me...my room mates jeep...the inside of the tires are outside of the body compleatly...and the cops have never messed with him about it...altho..i dont think he takes a corner at 35+ and drifts the corner with a CHP sittin less than 100 yards from where i was /forums/images/graemlins/eek.gif
