15" Wheels on a 14 Bolt SF or FF
Discussion in 'The Garage' started by Mudbug1979, Jul 23, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    15\" Wheels on a 14 Bolt SF or FF
    Are there any 15"x10 wheels that will fit on a 14 Bolt SF or FF? If so who makes them, unless anyone has any 16.5" 8 lug cheap wheels. I am converting over to 3/4 ton rear end and my 15/35/15 swampers and wheels aren't that old so the "Approval Committee" Will not let me buy some new wheels. I have a set of 1/2 worn out 36/14.5/16.5 if I can find some wheels.
    Thanks. /forums/images/graemlins/thumb.gif
  2. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    Re: 15\" Wheels on a 14 Bolt SF or FF
    4" backspace on 15"/10" wheel will do the job.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have a 14sf but it is a 6 lugger and I am running stock 15x8 steel rallyes on my 89 heavy half p/u...
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  5. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    if you can do it with 4 inch of backspacing then why does eveybody run 16.5 rims and keep popping beads? what's the downside to 15's? brake clearance?
    just wondering.
  6. Deadman514
    Deadman514 Registered Member
    Aug 28, 2002
    23
    just wondering.
    15" wheels clear the 14 bolt brakes fine (unless you run rear discs -then you need 2-1/2" backspacing) -it's the front 8 lug axle that the 15" wheels will hit the brakes on (with stock backspacing). Most people won't run 15"s in the rear and 16"s up front. I got 15x12"s with 2-1/2" backspacing to clear my 8 lug front brakes and my rear disc conversion on the 14 bolt.
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    With the disk conversion on my 14bolt I didn't need any grinding to fit the 15x10 3.5" backspaced steel rims.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As mentioned, most people do NOT have any problem fitting 15" rims on the rear axle. I ran 15x10 rims with 4.25" backspacing on my rear 14FF with the big brakes and had no clearance issues. Converting to rear discs also usually does not cause many clearance issues because the calipers sit further inboard than they would on the front, which basically has the same affect as running wheels with a smaller backspacing.
    Running 8-lug hubs in the front is where the clearance issues will be with 15" rims. With an 8-lug 10-bolt I had to do a moderate amount of grinding on the calipers to make the above rims fit, though I never worried about the strength of the calipers.
  9. Deadman514
    Aug 28, 2002
    23
    My rears would have needed a TINY bit of grinding. But since I was getting the 2-1/2" backspacing for the front -I figured I'd get a set of four. Now they all stick out the fenders equally.
    Yeah -I had the BIG brakes too -and the stock backspacing 15s fit fine.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Where'd you get wheels with 2 1/2" BS?
    All 4 wheel parts had was 4 1/4 for mine. I'm going to have to destroy my '60 with the grinder to get them to clear.
  11. Deadman514
    Aug 28, 2002
    23
    From National Tire and Wheel.
    Depending on who you talk to -they don't make them anymore. They DO. They're Bart/Stocton steel wheels. It says "custom backspacing available" on their ad. They were $85 each and took two weeks to ship (cause they had to be built).
    If you can't find them -let me know -I'll find them for ya.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nah. I'll just give my calipers hell and use the 4 1/4" bs ones. I like having my tires tucked in as far as I can anyway, and 16" wide tires are gonna stick out no matter what.
  13. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    I have 15x16 Eaton Chromes with 4" BS right now. But I'm about to swich to HMMWV wheels.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hmm...how much you want for the 15x16s?
