15" Wheels on D60 Front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan Melton, Mar 23, 2001.
  1. Ryan Melton
    Ryan Melton Registered Member
    Dec 15, 2000
    61
    Texas
    I know that I can run 15" Steel wheels on a D60 Front with some grinding on the calipers, but need to know how much backspacing I can / should run. I plan on running 44" Boggers on a 10" beadlocked wheel. (6" susp lift) Can I run 3 3/4" inches of backspacing on a D60 without the wheel / tire sidewall hitting anything? What about the tires as full lock? Will they hit the frame? I know Stephen Watson (ORD) is running 42's on 10" wheels with 3" of backspacing. I don't know if he is running this particular backspacing to clear components, the frame, or he just prefers that particluar spacing. Any help would be appreciated.
  2. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    Re: 15\" Wheels on D60 Front
    I know 4WheelParts has a bad rep, but when I ordered my 39.5X18s for my Dana 60, the salesman looked up the proper backspacing and I had zero problems. Act like you're gonna order from them and they'll look it up. Nice choice of tires/wheels! I wish I had gone 15". I can't air down as much as I'd like. See my trucks and action photos at <A target="_blank" HREF=http://www.bigerik.coloradoK5.com>http://www.bigerik.coloradoK5.com</A>.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Stephen Watson's 42s are only 15" wide, 44" Boggers are 19.5" wide. I would get 15x12s with 3 1/2" of backspacing. They're going to hit the fenders unless you do a lot of trimming, but that should keep them off the frame and springs. </font color=blue>
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A guy in our club is running a set of 15x10 whitespokes with the standard 4.25" backspacing on a front Dodge Dana 60. I'm not sure is the calipers and backing plates are the same, but I would think they were similar. Less backspacing usually means less grinding, though.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We put the 44" tsl's on Aaron Clough's Bummer with stockton 15 x 12's with 3" backspace and it took minor sanding of the caliper. Obviously the bodies different, but he didn't have any contact problems with the frame or springs. He would use a 10" wheel if he was buying them again though. Same backspace, just narrower. Course the bogger's are pretty wide compared to the TSL also.
    Making the world better, one truck at a time.
    SW-ORD
