15" Wheels on Dana 60 front Axle
Discussion in 'OffRoad Design' started by Brian 89KBlazer, Jan 9, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    15\" Wheels on Dana 60 front Axle
    Stephen
    I have been talking to Steve Fox and a few others trying to find info on this subject and was told that you are running this setup. The topic keeps coming up on the board but there doesn't seem to be a definitive answer and I'm hoping you can help. I know there is grinding required to clear a Dana 60 caliper. Two big questions would be what brand steel wheel to use and is the grinding excessive or dangerous??
    Steve said that there was about 1/8" clearance between his 16" cast aluminum wheels and the D60 caliper. Considering that the alum. wheel is much thicker than a steel wheel and that there is only 1/2 inch difference in the radius of a 15 & 16" wheel, there shouldn't need to be alot of grinding, should there??
    Thanks for any input you can give
    Brian
    89KBlazer
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: 15\" Wheels on Dana 60 front Axle
    We've had good luck with Stockton wheels with 3" of backspace. They still require some grinding, but it's in the neighborhood of .080" maybe? It's not major at all. I'm kind of squemish about grinding on a caliper and it didn't bother me at all. In fact on one we used a little sanding wheel, so it's not a big deal. You end up with a REALLY WIDE track if you use wide rims though. I've run 8" wide with 3" backspace, and currently have 11" wide (10" with beadlock) and 3" and now it's really wide. With the 8" wheels the track was just how I like it, a couple inches of tire out of the fender. It doesn't look bad or attract attention, but it keeps the rocks and trees off the body pretty well.
    Hope this helps
    SW-ORD
  3. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Stephen
    That's exactly what I was looking for!![​IMG][​IMG]
    Brian
    89KBlazer
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I keep hearing this only works with a single piston caliper. I looked at a d60 in a scrap yard here and it had dual piston calipers. It was also a dually. are single piston calipers common? what years used them?
    your right. I don't understand the jeep thing!
  5. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Thanks Brian. How's the weather on the rock?
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  6. JoeAngelicchio
    Feb 18, 2000
    628
    I can't remember but what is the normal backspacing for the rims?
    </font color=green>
  7. Brian 89KBlazer
    779
    Ontario, Canada
    Hi Joe!
    Lots of snow here on the rock! I hear you guys are getting your share as well!!
    I don't know what's considered "normal" for these wheels (maybe Stephen or someone else knows) but most of the different brands of "off-the-shelf" that I found had between 4" - 4.5" backspacing. I guess that's why some guys have to grind so much off the D60 caliper to make it fit.
    The wheels Stephen has seem to be the answer.
    Take Care
    Brian
    89KBlazer
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We're guessing factory backspacing on a 16" steel wheel is about 4". That's for the 6.5" width.
    SW-ORD
