15" wheels with 13" rotors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Feb 8, 2002.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    15\" wheels with 13\" rotors?
    I have a D44 and a 14ff, both with 13" rotors. Will I be able to run a 15" wheel? I know I can with the smaller 11" rotor, but wasnt sure about the larger rotors. What about the backspacing, 4" or 4.5"? One last question is where can I get the wheel spacers to make the rear the same width as the front and how big of a spacer is needed?
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: 15\" wheels with 13\" rotors?
    You can run 15" steel wheels but will have to grind the caliper to make it fit. I went with 3.5" BS to not have to grind as much. With 4.25 BS you have to grind allot.
    You need 1.5" spacers in the rear for it to match the front...
    Or a 14FF from a 1 ton van.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. outlaw612
    Feb 11, 2001
    2,342
    Thanks for the info, thats what I was hoping to hear!
