15" wheels?
Discussion in 'The Garage' started by chiefheaphy, Apr 25, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Is there an advantage to running 15" wheels over 16 or 16.5"?
    I'm going with 46" BAJA CLAWS.
  2. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    The 15's are usually cheaper and they have a safety bead that the 16.5's do not and therfore stay on the wheels better at lower air pressure. Also, more tires are avialable in the 15" rim size.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    u might wana run a bigger rim with 46's, the sidewall is going to be huge! id recommend a 20" beadlock.
    16.5 dont have the safety bead like the other sizes. the h1's are 16.5 and are double beadlock
    15's allow you to air down a bunch w/o beadlocks (still recommended)
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Yea if you are going with that huge of a tire, when you air down your steering response suffers (rims turn while tire stays put). I'd suggest some sort of beadlock on a larger rim. Not to mention if/when you do break a bead you risk damaging that expensive ars tire. I used to run 15s and on 2 consecutive rides I burst beads on 35" tires. The second time ruined the tire cuz i had to pull forward to jack it up. I run H1s now.
