15" wheels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevyTech, Feb 8, 2002.
  1. ChevyTech
    ChevyTech Registered Member
    Oct 22, 2001
    11
    Nebraska
    15\" wheels
    I'm just wondering if anybody can tell me if you can still run 15" wheels with a 14 bolt rear axle conversion?
    <P ID="edit"><FONT class="small">Edited by ChevyTech on 02/08/02 06:58 PM.</FONT></P>
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Re: 15\" wheels
    yes if you run a disc conversion and 1.5 spacers like I do. Not sure on a drum, but I don't think so unless you get some spacers or special backspacing on rims. The 1.5 spacers make the rear track width same as front, but not sure if that would be enough to clear the drums. Shedding the drums saves a heck of a lot of weight too.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: 15\" wheels
    Are you talking about after a disk conversion? If yes, you have to grind the calipers a little depending on the back space of the wheel. If drums, no worries as long as the wheels are steel. I'm running the big 1 ton rear drums with 15x8s and 4" back spacing with room to spare. As for aluminum wheels, it depends...
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: 15\" wheels
    <font color=blue>My 15x10 4 1/8" backspace wheels fit over the stock 1 ton drums and my rear disks with no problems. The only clearance issue is the front, you need to grind the calipers.
