1500 to 2500 swap info
Discussion in '1992-Present Chevy & GMC models' started by yunit, May 22, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Will a 2500 front diff. setup fit into a 1500 truck? I have a 92 fullsize blazer and I am thinking of swapping in a 4.10 front setup and 14 bolt in the rear. Thanks for any info you guys can supply. /forums/images/graemlins/thumb.gif
  2. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    A solid axle should swap , I believe. Probably would have to check on the braking diffences though if the sizes are different and address them, maybe with a different proportioning valve or booster.
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If the 2500 is 6 lug then it will fit. If it's 8 lug, it won't, different mounting points. The 6 lug 2500 are just heavy half tons, can't really be called a 3/4 ton IMO. The rear should go in no prob, joint may be the only difference.
  4. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I know I can get the rear to work, but was wondering about the 2500 carrier fitting in the front.
  5. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    6 lug fits...8 lug, no different mounting points
