15x10 8 lug?
Discussion in 'The Garage' started by low 84, Jan 18, 2005.
  1. low 84
    low 84 Registered Member
    Jan 4, 2005
    45
    college station, tx
    will 15x10's with about 3.5 b.s. fit on a 1 ton d44 front and a 14bFF rear with disc conversion?
    and if they will, does anyone know who makes an aluminum wheel thats 15x10 and 8x6.5, i can only find steelies in that size.
    thanks
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Got pics of that "1 ton d44 front" ??? Cause I've never seen one. A 8 lug Dana 44 is still just a 1/2 ton axle with 8 lug outers. You have too step up to a Dana 60 if you want a 1 ton front axle. They don't make aluminum rims in 15" and 8 lugs. You may have too grind your calipers, but no big deal.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    15" aluminum rims wont fit on a rear disk 14bff as far as I know
  4. low 84
    Jan 4, 2005
    45
    college station, tx
    i didn't pull the d44, i was just told it was pulled out of a 1 ton, guess it wasn't. doesn't matter i practically stole the d44 and 14boltFF both with 4.56's for next to nothing. i just wanted to run my 15 inch 35's on the 8 lug axles b/c it will be awhile before i can afford a set of 37's or 38's
    so will 15x10 steels with about 3.5 b.s. fit the d44 and the 14bFF with rear disc?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no one makes a 15x10, 8 on 6.5. I don't believe it woudl fit front or rear. Aluminum rims are thicker than steel ones so they there is less space inside the rim.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea they make 15x10 steelies, I got mine from summit racing, they are made my U.S wheels, and are white but i painted them black, good thing is sumit has no shipping just a small handleing fee.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ow and they are 4 1/4" back spacing, I had to grind a little bit off my rear calipers but just the little high spots in them :)
  8. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    4WP sells them...Rockcrawler steel wheels, 15x10 8 lug with 2.5 BS....and they WILL fit a 14BoltFF, 10 bolt, D44 and a D60 front with no caliper grinding.
    Bout 60$ a piece I was told.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea they will work but I dont like that much BS, I dont remember how much I paid for mine from summit but I thk they were cheaper than $60
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm screwed right now, probably gonna have to get 2.5" backspacing rims, Id on't want to but to fit on my dual piston calipers I have to.
  11. low 84
    Jan 4, 2005
    45
    college station, tx
    thanks alot man! i guess this is the route i will take. i want to get those axles under it asap but i don't have the money for another set of tires AND wheels right now and the 35 bfg's i have are pretty much brand new.
