15x10 8lug????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84BIGBODY, Apr 17, 2000.
  1. 84BIGBODY
    84BIGBODY Registered Member
    Mar 15, 2000
    20
    TN
    Does anyone know who makes a 15x10 8 lug rim.
  2. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    American racing does. At least in the Wagon wheel and chrome nugget. Also Bart monster Wheels.
    "You're right... I don't understand that Jeep thing!"
  3. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Will a 15x10 8lug rim fit on a 14 bolt ff,and a dana 44 hd.Do you know?
  4. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    I thought the reason the 3/4 and 1 tons have 16 in. rims was because of interference with the large rear drums and the front calipers. I have seen a few articles in 4W&OR that talked about slightly grinding the front disk calipers to fit the 15s but don't know about the rear drums.
    I am interested in this topic as well. I have a 77 K5 with the 6 bolt, but I just picked up an 82 3/4 ton SF Burb that needs rims fast !
    Overdrive
  5. UT77GMC4x4
    UT77GMC4x4 Registered Member
    Feb 24, 2000
    15
    UT--Salt Lake City
    I have a friend that works at Six States Here in Salt Lake, and I just witnessed him putting 15 inchers on a Full Float Blazer. He did have to grind the hell(at least 1/8" to 1/4") of material off of the calipers, but it ultimately did work. Let me know if you have any problems, because I think the 15 inchers would be nice to have because of the extra sidewall and I'm thinking of doing it.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have heard that (some) steel 15 inchers will fit over the 3/4 ton brakes (not 1 ton 13" drums). Aluminum will not, because of the thickness of the wheels. I think there are some steel 15" 8 lug wheels that are designed for this purpose. Choices are limited though.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  7. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Stockton Wheel Company can make some for you, but I wouldn't want to grind all that off the brakes. A set of 16.5's would be modification free to install.
    '73 K5
    Chevy good...Ford bad
  8. Rockblazer
    Feb 18, 2000
    114
    South Dakota
    Yes 15" will fit on that application. I am not sure if the 8 lug dana caliper is any bigger, maybe someone else does. I have 15 x 10's on my 60 and 14 bolt. No problem in the rear with 11" brakes. Some grinding on the front caliper. There is plenty of material there to grind off. Of course 16.5's are the easiest way to go, but if you wheel and let tire pressure low you will pop a bead much easier. 16.5's have no inner lock.
  9. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    What make are your rims?I was curoius because it seems easier to find used and replacment 15" tires around.And the bead thing too.How much did you have to grind off.
