15x10 rims with 33x12.5x15's... bead safe?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Mar 23, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    15x10 rims with 33x12.5x15\'s... bead safe?
    I might have to pop my 33's back on after my axle swap but plan on getting 15x10 rims for the future 38's. I imagine I might have some issues if I air down, anyone doing this that can comment?
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Re: 15x10 rims with 33x12.5x15\'s... bead safe?
    http://www.blazer-fest.8m.com/fe589808.jpg
    Here is a pic of my 33 12.50 15's on my 15x10 steel rim with about 8psi in them. Looks kinda flat huh? The only time I blew a bead was when I was coming out of a mud hole and my ass end bucked up and landed on my rear tire with a side force. Other than then I never blew a bead and I would run them that low quite a bit. You should be fine.
  3. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    Im running 15x10 rims on 18.5x44 with 5 to 8 lbs on the trails no problem. <font color=red>1 FN HI K5 <font color=red>
  4. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I ran 33x12.50-15 all terrains for a while with 15X10 wheels. I had no problems. I never aired it down, but it worked fine.
    Will
  5. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I envy your choice of tire but I need to stay as low as possible for the jumping and don't plan to move the cab or radiator to do so /forums/images/icons/smile.gif. I was more worried about such a thin tire on such a wide rim with the 33's.
    Esteban, 77Thing - Thanks, that will help get the 14b on much sooner! Although I still don't have a 8 lug front end... still trying to solve that one! If I do just the rear I've got to "Mall Poser" the 2x4 for a bit untill I compromise /forums/images/icons/frown.gif!
  6. Esteban86K5
    3,712
    Bakersfield, CA
    Just make sure you do it AFTER Azusa!!/forums/images/icons/laugh.gif
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    It's not like I'm going to need 4 wheel drive anyhow for azusa... my tires have such a tight tread pattern that they will turn into muddy non cleaning slicks on the first puddle! But yeah, I'll wait untill after!
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    My first borrowed set of tires were 32x11.5 on 15x10's and I aired those below 10 psi every weekend without ever having any problems with high speed dune runs. So if you are worried about rolling a bead, don't sweat it!
  9. hoserr
    hoserr Registered Member
    Jul 25, 2001
    78
    chula vista, ca
    i have 33's on my 10's. i've popped the bead once on the waterfall at our favorite place. i usually go down to 15 or so an hardly ever pop now.
