15x10's whats the widest tire?
Discussion in 'The Garage' started by coptezr, Mar 27, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    whats the widest tire i can put on a 15x10 inch rim? thanks
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    54
    Powell, Wy
    I've seen 44x18s on them no problem. I have 40x15 on mine.
  3. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    I know from running tires from Super Swamper they will suggest the rim size for the tire. Running a tire too wide/narrow for your rim size will cause the tire to wear improperly, but if that isnt a concern you usually <from my experience> can run what ever fits. I'm currently running a 19.5" wide tire on a 15x10 rim with Zero problems. Im able to run a low air pressure without problems<yet>
  4. coptezr
    Jan 13, 2005
    342
    holy #$%^ are you joking i just want a wider sixe for the bush wacker cut-outs so it will fill the back tire out i want good tire wear becasue is 60% street truck
