15X8 or 15X10
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Mar 29, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    I'm pretty psyched... I just installed a 4" pro-comp lift with springs in front, 4" blocks in back w/1" add a leaf... I mounted on 15X8's w/35x12.5.15 Question: It seems to look kind of narrow but I like it 'cause I didn't have to cut any sheetmetal... Would I need to do any trimming if I moved up to the Eagle 589 15X10's with the same tires??? What would the offset be? Any cutting necessary?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have a 4inch pro comp lift with 33x12.50x15 and my tires rub....Dan
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Eagle 589's 15x10 have a 4'' backspacing. Your truck looks narrow because the rear axle is 3'' narrower than the front, maybe invest in wheelspacers for the rear axle before you drop the cash for 15x10's
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    15x8's will keep the bead seated better on the tires. I think backspacing determines how much your tires stick out vs rim size.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    While I don't doubt there is no rubbing while driving on the street, if you ever do get into any type of flexed out situation off-road they will rub.
    Going from 15x8's to 15x10's (assuming they have the same backspacing) will probably cause the tires to be closer to the fenders and thus more likely to rub when turning. Years ago I switched from the stock 15x7 rims to 15x10's and they definitely put the tire closer to the rear edge of the front fenders when turned.
